How to block some contact
Deni007
Visitor
Good evening Xperia..i want to ask how to block contact,because there is no opttion to do that.tqFolded_HandsSlightly_smiling_Face
1 REPLY 1
Jonas
Master
Hi @Deni007, welcome to our forum!
The Xperia M4 Aqua does not have an inbuilt call blocking feature, so you will either need to download a third party application from the Google Play store, or save the number as a contact in the device and then make sure that all calls from this number is sent to the voice mail.
Create the contact as you would normally do, enter the phone number and in the top right corner you have three dots. Tap on these and then check the little box next to "All calls to voicemail".
I hope that helps! Slightly_smiling_Face
