Podziel się wrażeniami!
Rozwiązane! Idź do rozwiązania.
I just tried this and it works fine for me. Could you boot your phone into safe mode and try to answer a call with your headset?
Otherwise, do you have the possibility to try another Sony headset to see if same thing happens?
Do you have M2 or Z2?
Do you have smart key installed?
Which headset was included for your Xperia M2 Dual? You should have a label attached to your headset with the model number.
