only had this phone a week and its just dead. it was working fine one minute then screen went blank ive tried turning it on but its not responsive , tried leaving it on charge over night still nothing there is still a red light flashing but when its plugged in to the charger its not doing anything tired the on button and volume up but nothing help? or will i have to go back to carphone warehouse ?
Solved! Go to Solution.
omg thank you so so so much!! its come back on
its says its 91 % should i just leave it for 3 hours anyways then put the sim card and sd card back in ?
it'll be wise to reinstall the latest update with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
:smileywhew: Thankyou so much , I took the advice and HEY PRESTO. All systems Go!!!!!!!! It was like loosing my right arm. So very grateful for your help. xxx
Guys
Please could you assist me. I have the same problem but even when I plug my M2 aqua into a charger, not even a light comes on. I tried doing the volume and power button and the off button by the sd slot. WHat else can I do
