Apps/Home Screen keep deleting
Sonymanpro
Visitor
This has happened to me three times now.
It is very annoying,
So all Apps/Widgets/Ect. Will be deleted from the screens( Including the ones at the bottom Call/SMS/Settings/.
This happens sometimes after restarting my phone.
Is there a way to prevent this? Or a way to save that somehow? Because it's a waste of time to reorganize everything.
Thanks.
1 ACCEPTED SOLUTION
Uliwooly
@Sonymanpro
Try this
settings > apps > all > Xperia home > clear data > restart the phone > add the widgets and apps > check again.
3 REPLIES 3
Uliwooly
Have you moved apps to the SD card? Any taskillers? Clean sweepee app?
Sonymanpro
Visitor
I have no taskillers.
I have moved apps to the SD card.
Uliwooly
@Sonymanpro
Try this
