Stamina mode problem
RFXMariam
Visitor
Well i got a warning that (download music information) app disabled or made stamina mode don't work . So i dont use this app often and i use it sometimes but I think the only way to make stamina mode work is to force stop it..Is there any other way???, And if i force stopeed the download music info, would it work again??thank you
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
There will be no software update,only software repair.You can factory settings reset.
alexdon
15 REPLIES 15
Uliwooly
Could you take a screenshot of the error?
Screenshot = press and hold power & volume down at the same time
you are not going to damage your phone if you force close an app
RFXMariam
Visitor
Well. Thank you!! I actually cant screen shot cuz the warning didnt come again so i will just force stop the app
Uliwooly
If you get any more erros you could re-install the latest updates, also if you have taskillers, antivirus, battery apps, etc, they could be creating this issues
RFXMariam
Visitor
How could I re install the latest updates?? And it used to be 4days battery last while stamina mode now its only one and i forced stop the download music info .. Please help! Hope u answer Slightly_smiling_Face
_alexdon_
http://www.sonymobile.com/gb/tools/update-service/
Repair via sony update service.
alexdon
RFXMariam
Visitor
I'm sorry but isn't there any other solution? If i cleared the app's data would everything be fine?
_alexdon_
You could try this to reset stamina mode:
First,disable stamina mode.After,go to settings-apps-all-eco mode controller,force stop it and clear data.Restart your phone and enable stamina again.
alexdon
RFXMariam
Visitor
ahhhh eco mode controller not in all apps.. Broken_Heart
_alexdon_
How can that be?Try reinstalling with sony update service,it should show up there.
alexdon
