Which Surround Sound?
jlangler1
Which would be the better set up?
Sony HT-NT5 Soundbar and SRS-ZR7 rear speakers
or
Sony HT-ZF9 Soundbar and it's SA-Z9R speakers
I'm understanding that the HT-ZF9 sound bar is better than the HT-NT5, but the SRS-ZR7 rear speakers are better than the SA-Z9R speakers as they are high-res audio?
Thanks!
1 REPLY 1
Sonyvores
Contributor
"Sony HT-ZF9 Soundbar and it's SA-Z9R speakers" will be better because it's compatible with recent audio codec (dolby/dts etc...) and sound quality from the front speakers is more important than the surround
