To kd43xe8396 keeps switching on
lp0211
Had the TV about 1 month and it keeps switching itself on at random times, including middle of the night.  Have followed previous advice on here re switching timers/Bravia auto to off however still happens. No pattern to it.  Help!  Yours very tiredly...LP
1 ACCEPTED SOLUTION
lp0211
FYI in case this happens to anyone else...we disabled the Chromecast app and that's worked.  It's been picking up daughter's chrome cast and that of a neighbours!!  We now will only have that switched on if we need it.
4 REPLIES 4
Drewde
Administrator
Welcome to the Community.
Can you let me know what you have connected to the TV? Any consoles or other devices? Can you try taking the batteries out the remote when you go to sleep so we can rule out any issues with that.
Thanks,
Drew
lp0211
Hi Drew
It was discounnected from the amplifier (also Sony) a couple of weeks ago therefore nothing else connected to it.  I took the batteries out of the handset this morning and it has since turned itself on 3 times!
Pascale_F
Moderator
Hi lp0211,
This sounds really frustrating. It's best to contact Sony Support about this here.
Thanks,
Pascale_F
lp0211
