I had been using HDMI for audio with my soundbar. However, I have a new setup where volume control does not work that way with a new OS I am using. So, I bought a 3.5mm audio cable. I thought I could connect from the soundbar to the audio port on the Intel NUC. When I do this, I don't get audio unless I have the input set to ANALOG. But, when it is set to ANALOG, I don't get video from the HDMI. Is there a way to get them working together? Thank you.
Hi mystik1,
It might be best speak to Sony Support for further advice.
Thanks,
Sean Mc
