Sony bdv n790 surround amp problem
StewNi
Hi I have been using this system and it’s great however my rear surround amplifier has recently for some water damage and now the system doesn’t see the rear amp
as being connected (green light flashes) the item
number is ta-sa300 wr, does anyone know if there is a compatible amp that can be used instead as I’m struggling to find a replacement?
3 REPLIES 3
HannahEd01
Hi StewNi, could you double check the full model of the system ? I only found this:
BDV-N790W and it doesn't have the ta-sa300.
StewNi
Hi may be the 590 version
[cid:d19250f1-c29f-417a-b4c3-af4b8e99cfb2@eurprd07.prod.outlook.com]
Sent from my iPhone
Pentium_Gladio
Specialist
maybe check with an engineer if it can be repaired? Sony has a locator tool you can use;
UK locator: https://locator.sony/en_GB/servicecenters and one for Ireland: https://locator.sony/en_IE/servicecenters
