- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
netflix on N7100w
I dont have the netflix channel as an option on my new bluray system allthough it should be compatible. ?
Can someone please help me?
This was one of the reasons ni choose this system
Thanks in advance.
- Michael
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Yes, Netflix should be on there. Have you connected the bluray player to your home network? And can you see things like BBC iPlayer?
Basically I am trying to establish where you are with things?
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the quick reply. I am based in Denmark where there should be netflix as well. But it only gives ne things like lovefilm.
Thx a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Gotcha - Yes Denmark has Netflix
Have you tried performing a Network update?
If so, try the following
- Reboot your ISP's router
- Perform a Factory Reset of the N7100
- Redo all settings again (im afraid)
Hope that helps.
EDIT: Just noticed - On the remote control, there is a Netflix Button - What happens when you press it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thx a lot
Will try it out tomorrow...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No probs - Not sure if I posted in time - What happens when you press the Netflix button on the remote control.
