any one know where i can get a digital media port adapter for my home cinema system ,dav-dz230.cheers chris
Hi Chris. Is this for an Ipod, WIFI or others?
information needed!!
i currently have a sony dav-dz230, i am trying to buy the geniune sony digital media port, i would like to play music from my pc through the dz230 , without having to burn cds and then playing them on the dz230, would this digital media port allow me to do this? if i cant purchase the geniune item could you put me in touch with a alternative, i currently play music cds through this dz230, and for me its performance is brilliant.
many thanks.
Yes you can but unfortunately, Sony discontinued those DMP, you have to buy them from Ebay resellers.
In the meantime, you can for now use the audio line in and connect it to your computer
once I have connected the sound card out to a rca splitter box with a male
connecter to go in the aux- in on the dav-dz230, will the sound go to
stereo or full cinema sound?
Yes , you need to use the dsp (movie, cinema etc...) Since you have all that, you can try and "see" by yourself
Ive had a look at the back of my computer I
also have a hdmi port on my sound card, and the dav-dz230 has a hdmi-out,
if these are connected, would I get all speaker cinema sound? non since it's hdmi OUT and not IN
and lastly if I had the digital media port from sony for the dav-dz230 would this have
given me all speaker cinema sound from my pc? oushoould be via the dsp
