profile.country.SE.title
Stig-fjall
STR-DH590
Hej!
Jag måste använda en utomhusantenn ( 75 ohm) för att kunna lyssna FM radio hur gör jag?
1 REPLY 1
Joe_Dohn
Specialist
I assume you're looking for an outdoor antenna to use with your amp (at least according to Google Translate)?
Have you tried taking the antenna that comes with the amp to a nearby store to get one with the same port?
Hope this helps!
- JD
