AppleOrange
PS-LX310BT
I can hear music being played through the turntable when it is not connected to any speakers. When i have my turntable connected up to my speakers (using line from the turntable, and RCA adapter) i can hear the turntable noise over the speaker. There is also a delay between the sound from the turntable to the sound from the speakers.
3 REPLIES 3
HannahEd01
Hey AppleOrange, do you mean PHONO input jack, AUX input jack, or analog input jack for the audio device? Check page 12 for more info :
https://www.sony.com/electronics/support/res/manuals/4748/54031a965b2a74816d8a777cbcedf263/47487553M...
AppleOrange
The turntable is in line mode, i have an RCA to Aux cable to connect to my audio device.
Froobie
Hi Apple.
I'm guessing you mean the tinny sound coming from the needle - which is perfectly normal.
If you are hearing this teeny-tiny sound OVER that of the speakers, then I'm surprised!
Is the lid closed? If not, close it to block some of the sound.
Other than that, I guess you need to sit away from the TT and/or turn the volume up a bit.
It's normal, tho' - the needle has to vibrate according to the grooves...
