KD-50X89J White horizontal line. 😭
Peterbob
hi, curious as to whether anyone has has a similar issue. Not set specific probably but out of the blue whilst playing on the ps5 a feint white line appeared across the middle of the screen.
No matter what I'm doing gaming/4k player/ streaming its there.
Powered off/on checked/swapped cables between devices updated firmware, restarted and reset. Nothing works.
Anything i haven't done? If anyone has a recommendation id be grateful.
Peter
2 REPLIES 2
Anonymous
Not applicable
@Peterbob , follow this article here How to troubleshoot screen and picture issues on your Sony TV then contact the support team if you still have the line.
Peterbob
No I've jumped through all the sony hoops already but thank you.
Spoken to support people days ago a replacement is being sorted, here’s hoping i don't end up with a worse tv than i currently have.
i will return with the results when its finished with in case anyone else has a similar issue. Ta
