Camera advice
esheesle1
Camera advice
Any recommendations on the best camera for under $200?
1 REPLY 1
profile.country.BE.title
Portmixus
Hero
If 2nd hand is OK for you, I would look for a RX100! By far the best compact camera for the money!
(Or stretch your budget a bit!)
Otherwise, I would suggest an HX50(v). V is for gps, without v is without gps.
Of course, if you tell us more what you expect from a compactcamera (what your priorities are), it would help too :slight_smile:
_____________________________________________________
Sony Alpha Training
