My phone keeps freezing and then restarting 2 mins later. Any ideas?
Hi @sjaitken,
I'm sorry to hear this.
Does this happen at when you do something specific with your device? Like open up a specific app?
There are a few thing I would recommend that you try to see what may be the cause of this behavior. Try these tips one after the other, check after each one if there is a difference.
Let me know how it goes and if you are still experiencing the same behavior with your device after trying these steps.
When I remove SIM it works fine. What do I do now?
Then I would recommend that you try with a different SIM card and see if you experience the same behavior.
If your device still freeze and restarts with a different SIM card I would recommend that you get in contact with your Local support team for assistance with having your device sent in to an authorized service center for further troubleshooting and repair.
