annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Screen problem during a call Xperia E3
RÉSOLU
Teffi
Visiteur
I have a problem. My Xperia E3 turn of the screen during the calls even if i am not talking with it in my ear and do not let me cancel the call until the answer machine close the call. How can i solve it?? Please help. And thanks
1 SOLUTION APPROUVÉE
Solutions approuvées
Hi Teffi,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Can you advise if you are using some screen protector or case on that device?
These may very well be affecting the proximity sensor of the device, if so I suggest trying to remove them and then testing it.
Please let me know.
Voir la solution dans l'envoi d'origine
14 RÉPONSES 14
Teffi
Visiteur
Btw i plug the charger and does not worrk neither
Ashroft98
Passionné
How long have you been facing this?
And
Can you try this?
Go to Settings > About Phone > Diagnostic > Proximity Sensor test.
See if your proximity sensor works.
Hi Teffi,
Please let me know.
Teffi
Visiteur
Does not work
Ashroft98
Passionné
I see.
Then there might be a faulty proximity sensor.You may need to bring your device to a local Sony Xperia Center.But first you need to contact them.
Contact Local Sony Xperia
http://support.sonymobile.com/global-en/contactUs/
Teffi
Visiteur
Thanks my dear friend. The screen Protector was the problem. Then it means i can not use screen protector?
Phy
Légende
Légende
You can use a screen protector, as long as it doesn't cover the proximity sensor.
Teffi
Visiteur
Thank you but how I know which is properly without spend my money in vain?
Uliwooly
