proximity sensor problem
LordOfInternet
Visitor
Sorry for posting here, but there is no any Xperia E4 forum to post. If there is any, please transfer the thread there and let me know.
As I already mentioned, I have the Xperia E2105 phone. The last weeks, when I perform a phone call the screen turns off, even before I place it by my ear, and after the call the screen doesn't recover. I have to force restart the phone to turn the screen on again.
I sent it for service but the problem wasn't solved. What can I do?
Thanks in advance.
Topic moved to E4 board by Hampus.
1 ACCEPTED SOLUTION
thejavigames
Visitor
Hello you have any protective film on?
if you have that might be the problem because many plug the proximity sensor
Cheers
13 REPLIES 13
Hampus
Champion
Could you try the ear proximity via Diagnostics? Diagnostics can be found via Settings > About phone > Diagnostics.
thejavigames
Visitor
Cheers
LordOfInternet
Visitor
The diagnostics test fails. And yes, I have a 3rd partie's tempered glass 9H 0.3mm screen protector on. Could it be the cause? Its package said it is compatible with the phone's touch screen and does not affect its functions.
Uliwooly
@LordOfInternet
You should remove it and test it w/o it, make sure to clean the screen and proximity sensor after you remove it
LordOfInternet
Visitor
Where exactly is the proximity sensor?
Uliwooly
LordOfInternet
Visitor
OK thanks, I ' ll try it tomorrow. It seems logical to me. I'll let you know.
Uliwooly
@LordOfInternet
keep us updated
LordOfInternet
Visitor
You had right guys. The protective sleeve caused the problem. I removed it and now the device works fine. Thank you all!
