I do not read the memory card that I can do ..
GT
Hi @Kary3,
As this is a international community your previous post has been translated in to English using Google translate. Please keep all future posts in English so that other user may more easily understand you.
I'm not quite sure I understand you question. Does your device detect your SD-card? Or are you experiencing difficulty when you try to transfer data to a SD card? If you could elaborate what it is you need assistance with I will do my best to assist you.
Hi! With my phone I have the same problem: it doesn't read my SD card so I cannot transfer my files into it. But it just happened out of the blue: since a couple of months ago it worked. What can I do?
Thanks a lot
See if you are able to format your storage card (Settings-->Storage & memory) - you will need to have a poke around in this menu, as it varies slightly between Sony smartphones, but it should be pretty obvious, if the smartphone is detecting a storage card at all...
Do you get an error message or see any symbols in your status bar (particularly ones that look like a storage card)?
Does the storage card work in other devices or computers?
