annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
Help
Cin291988
Visiteur
Help
Help
Hello, I want to know if I can update the software of my cell phone with the data activated. Thank you
Ayuda
Hola quiero saber si puedo actualizar el software de mi celular con el datos activado. Gracias
1 RÉPONSE 1
Uliwooly
@Cin291988
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Yes you can, however it will use a LOT of your data, not recommended.
