I bought Xperia E (secondhand), and it was okay for the first 2 days.
Later on, I couldn't open PlayStore even if I'm connected to a wi-fi network. A popup message always shows up saying "Unfortunately Google Play has stopped working". But at the same time, I can use Facebook, Twitter, and WhatsApp normally. This popup message comes up in every few seconds and it's very annoying.
Also, my contact list was gone (invisible), but when I search my contacts, they just appear.
Does anyone have clue or met the same problems? Please share your thoughts.
Solved! Go to Solution.
open the phonebook > menu > filter > select where you have stored your contacts > voila, done
few things that could be acting up, if your connection its too slow you will get that error, also you can try this
settings > apps > all > play store > clear everything > restart your phone
Don't forget to mark the Correct Answers & Helpful Answers
I don't really think you have to repair your phone but this is how if you want to do so
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
If I do this, does it mean that all apps will only be signed out?
How about my 'invisible' contacts? Any way to fix that, besides doing a factory reset to my phone?
everything will be gone, the only thing that will remain will be your pictures, music and videos.
what do you mean "invisible contacts"?
uninstall any of the following
antivirus
task killers
task managers
battery apps
ram apps
booster apps
restart your phone and check again
But I can still restore my apps after I do settings > apps > all > play store > clear everything > restart your phone right?
When I open my contact list, there is no contacts at all, just plain empty except for 'Myself'.
But when I type a contact in the search box, it appears, and I can send messages or call the contact. What kind of problem is that?
Ah. I see. It worked. But I don't feel like I have filtered my contacts in the first place....
that's random, but I'm glad it worked out
