Google Assistant Built-in Wireless Speaker (LF-S50G)
1,003  Views
Have a burning question you need answered sharpish but your hands are full? Or maybe you’re running late for a meeting and want to find the latest traffic and travel details? Let Google Assistant assist you! Our new wireless speaker, the LF-S50G, combines Sony's high quality sound - from a 360° speaker system - with help from your Google Assistant.
Features at a glance
Manage everyday tasks
Set a calendar event. Set an alarm. Check on how your favourite team is playing. Check traffic. And take care of your life without ever touching a button.
Enjoy 360° high quality sound
Hear the same great sound from anywhere in the room. And feel more from your music, thanks to a two-way facing speaker, two-stage diffuser, and bass reflex duct.
Get answers
Looking for recipes, unit conversions or nutritional information? Just start with 'Ok Google' to talk to your Assistant. Don’t forget the awesome jokes she can tell. It’s a blast.
Listen via BLUETOOTH® technology
Built-in Bluetooth® technology lets you listen to audio from a range of devices. For even easier connection, One-touch NFC makes pairing compatible devices as easy as a tap.
Touch-free gesture control
You can control the volume, pause, or play audio without being vocal. Just wave your hand over the top – no contact required.
Auto volume control
Automated volume control adapts to noise in the room so you can always listen at a comfortable level.
Splashproof
Your speaker can handle a little water, thanks to an IPX3-rated splashproof design. You can even take the cover off and rinse it under the tap.
Clock display
With an LED clock display, you never need to ask Google for the time. You can dim or turn it off to minimise electric light in your room.
We hope you enjoy our new, stylish speaker!
By the way, what do you ask your Google Assistant help with? Share your suggestions in the comments section below.
