phmorga75
Sony HX90V WiFi
Having upgraded to IOS 13, Imaging Edge Mobile no longer connects to the camera. Sony suggested using the QR code on the camera to connect, I found the QR code within the Remote Control App on the Camera which enable a connection to be made. After exiting the app it was possible to connect with Imaging Edge Mobile as normal. Hope this helps others.
1 REPLY 1
IamNic
Hello @phmorga75,
thank you for sharing this tip.
- Nic
