DSC - HX400V Camera Memory
Dunworkin
Hi All - I have a 32G SD card in my HX400V but receive 'Card Full' message at only 4G.
Is there anywhere within the camera that I can check that the 32G is recognised/available ( less any used memory) or some indication of remaining/empty SD card space?
The 32G registers OK on a card reader.
Any advice appreciated.
Many Thanks
Dunworkin
1 ACCEPTED SOLUTION
Dunworkin
Hi Betreff - Firstly...Sincere apologies for not replying sooner to your response, for which I thank you.
Card is a SanDisk and genuine (as far as I know!).
Problem seems to have righted itself.  I managed to track down camera card volume.....stupid me expeceted it to be listed under 'Memory' when it is actually detailed under the heading 'Media'.
Thanks again for your response.
2 REPLIES 2
IamNic
Hello @Dunworkin,
which card are you trying to use and where did you purchase it?
To me it sounds like a counterfeit card, which has less memory than it suggests to have.
- Nic
Dunworkin
