When i try to download PMB Blu-Ray Disc Add-on Software with "DownloadManager_1005a" I receive message "The supported camera is not connected.", even though it is. Camera is connected to comp with USB. I don't have any other problem with connection and PMB works fine with camera
Please help.
Windows 7 profesional x64
Camera HDR-CX115E
PMB 5.5.02
It is becouse of update version 5.5.02
Deinstall it and install basic PMB version from original disc again. After that You will be able to install bd add on SW
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/disk/bd.html
http://support.d-imaging.sony.co.jp/BDUW/bd_addonen.html
Regards
Damac
