difficult to login in Linkedin
cris2015
Visitor
Hello Guys
I can not login to Linkedin throught Xperia C3. System say the mail or password are bad. I change the password and login again, the problem is the same, agaim and again.
When I use the router wifi Mode connected with my notebook, No Problem. Whats the matter. Can you help me.
I had wrote to Linkedin but they not respond.
Thanks
Cris
1 ACCEPTED SOLUTION
Rickard
Master
Not sure what could cause this, sounds like something that needs to be checked by LinkedIn. But see if the same thing happens both using Chrome and their app: https://play.google.com/store/apps/details?id=com.linkedin.android
2 REPLIES 2
Rickard
Master
cris2015
Visitor
Thank You Slightly_smiling_Face
