XR8595JU dimension for wall mount
adi-pa
Hi
I'm aware the dimension for VESA is 400 x 400.
What I'm looking for where exactly are the VESA holes on the TV. I need it mount at the exact allocated space.
TV dimension is 1888 x 1086 (W x H) so horizontally the two holes would be 744 mm away from right and also left.
I'm not sure vertically where the holes are positioned, as generally, they vary from TV to TV.
Based on SU-WL450 wall mount (I'm not using this mount) manual it seems it's 394mm from top and 292 from the bottom, but I'm not sure.
7 REPLIES 7
royabrown2
Hero
@adi-pa
It’s extremely rare to get no hits at all from Google for something, but that TV model number manages it 😢
royabrown2
Hero
@adi-pa
This version of that Sony mounting bracket manual (there seem to be several versions) has the most comprehensive set of measurements.
https://www.sony.com/electronics/support/res/manuals/F530/160a5a2e7689cdbd875e63014a190e56/F5301001M...
But maybe it’s the one you have already looked at?
There’s a WL850 mount as well, might have more into in its manual.
adi-pa
Google often fails when info is incorrect. My bad, its XR8595JU 😬
adi-pa
royabrown2
Hero
@adi-pa
ISTYM XR85X95JU… 😀
rooobb
adi-pa
Thanks a lot @rooobb,
this is exactly what I wanted (but could just not find it).
Appreciate the help
