vertical blue line in screen
BearFowler
Hi guys,
I have a KDL-43W756C that has developed a thin line blue line running vertically near the about 1/4 away from the left of the screen. Appears on all inputs.
Any suggestions as to what this could be or how to solve it?
Thanks
Michael
11 REPLIES 11
Mooly01
Contributor
From your description this unfortunately sounds like a hardware fault (faulty screen). I take it you mean it is a very sharply defined line perhaps just a pixel or so in width. I hope this is under warranty.
BearFowler
Hi Mooly01
You description is correct and confirmed what I was thinking.
The downside is its 18month old. I'll contact the retailer.
Thanks
Michael
Mooly01
Contributor
You can try contacting the seller although I don't believe they have any statutory duty once outside the guarantee period.
Where you might get some success is by taking this up with Sony and bringing to attention the 'Consumer Rights Act 2015' (which replaced the old sale of goods act). Have a read '9' here. It is certainly reasonable to expect a premium brand TV to function satisfactorily for more than 18 month before suffereing a problem that renders it essentially beyond economic repair.
Good luck... and don't be put off.
BearFowler
Thanks for the link, I was actually reading a bit about SOG last night but never got as far as the actual act itself.
I think it is actually the seller that has the resposbililty regardless of when the issue happens.
Thanks again.
Michael
Mooly01
Contributor
Yes, you could be correct on that. I was thinking as it was past warranty your claim could fall to the manufacturer...
Some useful info here:
Consumer rights
Fwiw, I've had two products replaced under the old SOG. One was the infamous original Daewoo Freeview first generation set top box. That was 6 yrs old as I recall when changes to the transmission system rendered it (and thousands of others) useless. Contacted Daewoo over that and was sent a new model.
Second was a Panasonic DVD recorder that also was effected by transmission changes. That would have been a couple of years old. A promised update was slow to materialise and so I confronted Argos and secured a replacement model.
And finally our old Sony 32" IDTV that was a few years old when a requested channel rescan (again Freeview changes) caused no channels to be stored and receivable. A software update should have been issued before the change, following the change and rescan it would never be received. I complained to Sony and secured an engineer visit complete with laptop and revised software to install. Sony initially wanted to charge this as a service call but I argued on the grounds the product was sold as 'future proof'. They immediately said they would cover the cost.
So go for it :slight_smile:
BearFowler
Excellent, cheers Mooly01.
Ive sent the retailer a message, lets see what they say.
Mooly01
Contributor
Good luck, and let us know how it all goes.
BearFowler
So first shots fired, Usual responce its out of warranty contact the manufacturer..............
BearFowler
dropped the Consumer rights act into the conversation,
Mow we are onto the engineers report section. Hopefully the TV shop at the end of my street will do that for me at a resonable rate.
Now just to find the receipt!!:thinking:
