TV switches off on start
RRG-Fafnir
Member
When I switch on the TV (KD55A1) with the remote, the white indicator on light glows and the TV then switches itself off. If I try again, it usually switches on and stays on
17 REPLIES 17
EdwinaU
Moderator
Hi there,
We will check this and update you when we know more.
Until we get back to you someone else in the community may be able to help.
Best wishes,
Ed
Win_88
Specialist
Hi RRG-Fafnir
Does unplugging the TV from the mains for a minute help?
When did this start to happen? Was there a new software update recently installed?
Win_88
RRG-Fafnir
Member
The problem developed about 6 months ago , no new installs involved so and I mentioned it to my local Sony shop. He referred me to yourselves, but it is not too much of a problem to press the On button again, but I  finally thought I should mention it. I did try the re-boot method, suggested also by my Sony dealer, but it didn't make any difference
Vanilla_
Contributor
Hi RRG-Fafnir,
This could be just a glitch. Have you tried to fully reset the TV to factory settings? You'll find the steps in this article: https://www.sony.co.uk/electronics/support/televisions-projectors/articles/00122829
Hopefully, this will sort it out,
Vanilla_
jgn88n
Member
Yup, I have the same issue. I thought it was a surge to the power unit following the storm last night.. but it worked earlier in the day and then would not turn off.  Now my TV turns on only if I long hold press the power button (remote or on the TV)  and only loads as far as the colourful 4 dots on the android screen. I have tried the factory reset ( power and volume buttons) 5 times and no joy. Really annoying if this means the TV has died.
KenTolu
I have also got the same problem on my KDL-65W850C TV. The problem started yesterday morning. I have tried all the usual things, i.e. disconnected all other inputs/outputs, disconnected mains power for at least 6 hours then reconnecting. When I plug the mains in, the TV tries to run the android startup, i.e. the 4 animated coloured icons appear on screen for about 20 seconds, then the TV just shuts off for about 1 minute before trying the same startup procedure again, with the same result. This just repeats for as long as the mains power is connected. I hope there is a solution available soon.
Kind regards
Ken (in NZ)
jgn88n
Member
Same here! Exactly the same. Hope we can get some answers. I’ve emailed Sony as their customer service centre doesn’t operate over the weekend (it’s now 7.45 am in the UK)
RRG-Fafnir
Member
I tried the reset, what a chore to reinstall everything and set up the screen the way I like it. My problem has not  yet re-occured, but it was always intermittent. I will keep you posted
The_Black_Rose
Specialist
Hi RRG-Fafnir,
This sounds very strange. Let us know if this happened again.
Cheers,
The_Black_Rose
