TV shows recording problem
ThomasTag
I have these problems on my new Sony KD-55A8:
- I cannot record a program on one channel and watch another channel at the same time (direct UPC digital coax connection between TV and wall plug). Nothing else.
- I cannot program the recording of two programs that follow each other because they "overlap" it says. (as each one starts 5' before and ends 5-15' after (adjustable)). (Nor do two overlapping programs on two separate channels).
FYI, recording storage is a MyPassport 1TB hard drive connected to the USB socket specifically intended for this. Performance test passed by the TV diagnostic OK.
Thanks for help on this.
Thomas.
1 ACCEPTED SOLUTION
rooobb
Your TV spot twin DVB-T (Terrestrial) and DVB-S (Satellite) tuners, but only 1 DVB-C (cable) tuner: so depending which one your are using, you may or may not watch another channel while recording. (btw also using the twin tuners, you may be blocked if using a CAM for encoded broadcasting)
You selected the adjustable before-start and after-stop recording time so two program one after the other are not possible. You can however set to 0 the configuration (I would not suggest to because you risk to loose begin/end) or manually change the first programmed recording end to include also the second (if on same channel). Or adjust the end in order to fit the two.
2 REPLIES 2
rooobb
HannahEd01
Hi ThomasTag, the TV has twin tuners (Satellite and digital) Check the specs here: https://www.sony.co.uk/electronics/support/televisions-projectors-oled-tvs-android-/kd-55a8/specific...
try unplugging the TV from the mains for two minutes and disconnect any external device.
