Turning on by itself.
jumpedfromtoshiba1
Hi all, I have a KD-50 X81J TV that is two years old and has been flawless until recently, it has randomly started to switch itself on. I can get up in the morning or come in from shopping say and it has switched itself on. I have just done a factory reset and it has also got the latest firmware. I've also noticed when doing the factory reset it will not let me perform the sound calibration it just keeps saying calibration has failed. Any ideas would be gratefully received.
2 REPLIES 2
Anonymous
Not applicable
@jumpedfromtoshiba1 , do you have any timers set on the TV? Make sure that this function is off from this link
 Is the current Software v6.7546 ?
jumpedfromtoshiba1
Hi thank you for your suggestion, yes I have the latest software update and I have no timers set. I have done a factory reset and up to now the TV is behaving itself. I will keep an eye on it and fingers crossed. Thank you again for your time and ideas.
