Sony xf90 android 8.0 problem
profile.country.SE.title
Brag93
Hi. Reccently uppgraded my tv.
A accidentally pressed something in the accessibility menu..
now when I press the select button (middle button) (OK button) nothing happens. The led light on the TVs edge reacts but not the tv itself.. help me.....
2 REPLIES 2
LightFoot
Specialist
Hi @Brag93   I wouldn’t spend time trying to find what’s wrong. Simply perform a reset or factory reset to return to the defaults setup quickly.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/articles/00170595
Brag93
I have done so many settings....
cant you reset only the Android part of the tv? So the picture settings still are there?
