Sony KD49x8305c - Media streaming only works via WiFi
pcaplan
Hi All
Just got a new 2015 Bravia and love the picture.
One issue that is really bugging me however - I have a home network with several Media Servers on it. This TV can see the Media Servers (Google Video etc) when the TV is connected to the network by WiFi However when I have the Network cable plugged in for faster performance (same network) the Media Servers are no longer visible. I have checked all the usual suspects and other devices connected to the same network can pick up the Media Servers with no problems.
Anyone else experiencing the same problem? or better still have a solution!
6 REPLIES 6
profile.country.en_GB.title
petsmart
Member
I'm am having a similar issue but at the same time I can't use YouTube google play cast to the TV etc? Is this the same? I tried wireless though and had the same issues...I'm the 55x85c new 4k range,
psp888
Member
I am having the same issue.  Works perfectly on Wifi, but if I use a ethernet cable plugged into my BT Home Hub 5 router, it cannot see my Western Digital myCloud network hard drive.
Anyone found a solution?
psp888
Member
So strange, it started working. Turned tv on and WIFI wasn't connected and wouldn't connect, so plugged in network cable and since then it can my NAS with ethernet.
k11jrp
I'm having the exact same problem. NAS is found fine using wifi but not with a cable.. Yet when cable is connected I can use internet, youtube etc, it just wont find DNLA NAS server... Ive tried switching the WiFi on and off etc.. did you get a fix for this??? Thanks
psp888
Member
reboot your tv and router, should be ok after that.
k11jrp
Tried this now several times. The TV will simply not run my QNAP NAS over a wired network. Only via WiFi. Poor!! But thanks for the suggestion
