Sony Bravia turns itself on randomly
lukefildes
Hi
I have just bought a Sony Bravia KD49X83 4K Ultra HD Android TV. I have a problem where the tv just turns itself on all on it's own at any hour randomly. I do not have any timers set. Does anyone else have this problem
There are no lights flashing or anything
Thanks
60 REPLIES 60
ccarmock
Member
I have the same problem on my KD-48A9 even on the latest firmware - if I watch a recording on my Panasonic recorder and turn the recorded off and then use the TV  as normal most times when I turn the TV off it will come back on a few seconds later.   If I hold the power button down and chose restart it will restart and the fault is gone until the next time.
Sony blame the Panasonic player - however if that were the case a TV restart would not fix it.   Then they tell me to deactivate CEC - but that's a feature I want to use.
No USB devices are connected to the TV
