Sony Bravia KDL49WE753
profile.country.IE.title
Tom1ie
 Hi all
The sound on my bravia has suddenly stopped working. It was fine yesterday and has stopped today. I have unplugged the soundbar but the TV speakers aren't working. The volumes turned up, the TV's not on mute.
There is no sound on you tube or Netflix apps.
When I press the options button, I scroll down to audio, but I all I can select is dual sound and advanced settings in that menu. The dual sound option keeps intermittently greying itself out and making that option unselectable.
I have tried plugging it out for 60sec and that hasn't worked.
Any ideas?
2 REPLIES 2
Tom1ie
Ok just figured it out. I have to press the blue home button, then press options. This brings up a menu on the right hand side of the screen. I then scroll down to speakers, press select, then make sure TV speakers is selected.
I pressed the options button before but not on the home screen. You will get a different menu without the option to select TV speakers or audio system if you do it this way.
Pascale_F
Moderator
Hi Tom, and welcome to the community.
Glad you sorted it! And it might be helpful for other KDL-49WE753 users too, so thank you for updating the thread.
Thanks,
Pascale
