sony bravaia 49inch tv
could you tell me the size of the 2 bolts which go into the back of the Bravia 49 inch TV for wall mounting e.g. dia/length
thanks
1 REPLY 1
LightFoot
Specialist
Hi @Alfaromeo1   That all depends on the model number of your TV. It will start with KD.
https://www.sony.co.uk/electronics/support/articles/00176297
If you want the genuine parts then search https://www.sony.co.uk/electronics/support/articles/00176297
Examples +PSW 6x20 but in reality for this example would be any M6x20 with an appropriate head.
