Sony a90k with Sony HT-S40R
srjohnston80
I have just got the Sony A90K 48" TV.  I am very happy with it.  I decided to get the Sony HYT-S40R sound bar to go with it.
I have the sound bar plugged into the HDMI 3 earc port on the TV.  I also have a Sky Q 2tb box plugged into HDMI 1.  If I have the sky box turned on and watching TV, then decide to turn on the  sound bar, it turns on and a toast message appears say it has connected.  The problem is when it connects the screen goes black for a second or 2 with the toast message.
It is a little annoying.  It doesnt happen if I use bluetooth, the toast message appears over top of the screen.  Is there any recommend settings to stop the black screen happening while the soundbar connects.
13 REPLIES 13
royabrown2
Hero
@srjohnston80
Toast?
LightFoot
Specialist
@royabrown2 wrote:
@srjohnston80
Toast?
Streetband 1978.
LightFoot formally known as SonyUser30Yrs.
srjohnston80
Hi @Elodin
Is there a way that I can setup the soundbar via optical?  I tried Bluetooth but my Samsung Q950A does not auto connect to the TV.  I have to go into the bluetooth menu and connect each time.  My Sony mk4 and mk5 headphones auto connect each time I turn them on.
Optical cable could be the way to go if I can get it to auto connect when it turns on
Anonymous
Not applicable
Yea you can also test it with an optical cable, I think it even comes with it in most cases.
