No Firmware Update for KD-55XG9505 ?
Pat100
Member
Just being hypothetical as I don’t think I need one.
When I go to the Sony Support website and enter my model number, it doesn’t display a firmware update button. Should it?
2 REPLIES 2
LightFoot
Specialist
Hi @Pat100
You are correct, there doesn't appear to be any updates available for your KD-55XG9505 at this time.
Note, if you install the "Support by Sony" app on your phone or tablet you will be alerted when an update is available.
https://play.google.com/store/apps/details?id=jp.co.sony.support&hl=en_gb
https://apps.apple.com/gb/app/support-by-sony-find-support/id948089375
Pat100
Member
Thanks!
However, I was expecting to see the current firmware still available for re-download for folk who might have damaged their implementation in some way and wish to redo it.
Maybe this isn’t the way Android works? (Like reinstalling Windows over itself)
