No Event Information Sony Bravia 2016
Anyone know how to have programme names displayed in the tv guide rather than only "no event information"? i can only get the name after going onto the channel!
4 REPLIES 4
profile.country.AT.title
Kuschelmonschter
Hero
See my bug tracker. Probably you are suffering from this issue?
Anonymous
Not applicable
Hi there
Are you using the satellite tuner on the TV by any chance?  If so, this is as per design.    Freesat is the company behind the EPG for satellite tuners in the UK. Sony TVs are not Freesat compliant, which means only a basic EPG is included.
If you are using Freeview and getting this message, I would suggest checking your aerial connection and retuning your TV.
Cheers
asandhu1
I am suffering the same issue - I may have though twice about purchasing this if I had known about this isue in advance !
Is this the bug referred to in another thread  - Betreff ?
Anonymous
Not applicable
Hi @asandhu1
It is not a bug unfortunately and the TV is functioning as per design.  The TV was never designed to have a "Freesat" EPG, and hence Freeview only.
Further information in this thread:
https://community.sony.co.uk/t5/other-tvs/sony-bravia-tv-epg-quot-no-event-information-quot-on-frees...
Cheers
