My tv is blocking
profile.country.RO.title
Liviu27
My tv is blocking
After the update to android 8, my sony bravia 55xe8096, is blocking for a couple of minute. This happens when i change the tv station.
2 REPLIES 2
Pascale_F
Moderator
Hi Liviu27,
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Liviu27,
That's a bit unusual. Does this only happen when you're using the channels? Have you checked the signal strength?
Cheers,
The_Black_Rose
