My TV guide has disappeared? Can't scroll up or down channels either. Can anyone help?
Cmichaelam
2 REPLIES 2
Cmichaelam
Its returned!
If you're using OTA antenna (rabbit ears...) rescan the channels and this should fix the guide issue. I wasn't able to scroll down past the 3rd row and could only scroll up and rescanning the channels fixed the sony android tv guide problem.
