- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi everyone. I've got a Sony KD49X8309CBU and for some reason I can't pick up any digital signal through the antenna so I can't set up the you view. The signal through the dish is fine. I've tried the antenna in another TV and that definitely works. Is there something I can try?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
In order to help you, i think we need to take a step back and go back to basics first.
- Can you confirm that you have an aerial on your roof or in the loft that is capable of picking up a terrestrial 'freeview' signal?
- Can you confirm that an aerial lead is connected to the TV. Please do not use the satellite 'screw in' connection on the TV.
- Is this aerial lead of good condition (i.e. not damaged)?
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
You must use the DVB-T2 tuner on the TV and pickup a 'freeview' signal.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Aj1soad wrote:Hi everyone. I've got a Sony KD49X8309CBU and for some reason I can't pick up any digital signal through the antenna so I can't set up the you view. The signal through the dish is fine. I've tried the antenna in another TV and that definitely works. Is there something I can try?
Hi
Be aware that activating YouView will delete all your satellite tunings - you have to choose which of the two you want.
But broadcast Freeview coexists with satellite, so try ignoring YouView, and doing the Freeview tune-in that Quinnicus suggests.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks for the reply. ITV player and 5ondemand wont work without the Youview though. ive tried disconnecting the dvb2 cables and conected a normal antenna to the antenna port and its not picking anything up. do i have to delete the channel list on satelite first or should it do an auto wipe when doing the antenna scan?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Aj1soad wrote:thanks for the reply. ITV player and 5ondemand wont work without the Youview though. ive tried disconnecting the dvb2 cables and conected a normal antenna to the antenna port and its not picking anything up. do i have to delete the channel list on satelite first or should it do an auto wipe when doing the antenna scan?
Demand5 is available outside YouView - it's All4 that isn't, along with the ITV Hub.
And just retune - no need to delete existing tunings first.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry did mean 4od. But I'm still not picking any signal from the Antenna scan. Any idea?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Got it sorted out now. Ended up having to do a factory reset and it picked up the signal then. Thanks. for the help
