KD-65A1 HDMI Rename with Oreo
russelljfkirk
Hi All,
Has anyone been able to achieve this?
I can enter the new name via phone or iPad keyboard and the Sony remote control app but there seems no way to make the TV accept it. Keying enter, using the centre direction button have no effect and pressing Back looses the entered text.
I renamed other inputs before the Oreo update without issue. I’m trying to rename HDMI 2 to AppleTV. Shortening the name makes no difference.
On the latest release of software with auto update turned on.
Russ
1 REPLY 1
Anonymous
Not applicable
Hi there,
Have you tried a factory reset?
Best wishes,
M
