KD-32W800 Analogue
Hemyock2024
KD-32W800 Analogue
Recently purchased a KD 32 W800 i UK
On tuning the TV on antenna the fine tune analogue tuning option is greyed out and there is no option to tune analogue channels, only option is Freeview
Is there a way to enable analogue tuning?
4 REPLIES 4
daveyh64
Contributor
The last analogue TV signal/ broadcast was switched off in the UK in 2012, all terrestrial TV
received via a conventional TV aerial / antenna is broadcast as digital.
Hemyock2024
I need to connect to an internal analogue RF system, hence I need to enable the analogue tuner
daveyh64
Contributor
Perhaps you could explain your situation a bit better.
What is your internal RF system.
From memory when first setting up the TV you are asked whether to select Analogue or Digital.
Otherwise press the Quick Settings button on the remote control.
Select Settings on screen.
Select Channels & Inputs.
Select Channel Set Up.
Select Auto Tuning. (or Manual tuning)
From the next on screen menu select Analogue.
These are the options on my Sony TV XR-42A90K, your TV is a different model and
therefore may have a different menu set up bit the above may guide you in the correct direction.
royabrown2
Hero
@Hemyock2024
Here’s the manual for your TV, open at the page you need:-
https://helpguide.sony.net/tv/iaepm1/v1/en/2_2_6_analogue_manual_scan.html?hl=analog
Have your analogue RF system connected and operating, so the TV can find it.
