HBOGO
Doresc instalarea postului HBOGO pe TV SONY ANDROID 2018 DIAG 124 CM
2 REPLIES 2
EdwinaU
Moderator
Hi RodicaCristea,
Welcome to the community.
Please could you tell us the model number of your TV and translate your replies into English.
Thanks,
Ed
profile.country.RO.title
13commander
English version below
Ceau RodicaCristiea,
HBO tocmai ce a lansat aplicația Go pentru Android TV. S-ar putea să nu apară încă pe aplicația magazin play de pe televizor. Dar, ar trebui să poți să o instalezi direct de pe pagina web din magazin play.
https://play.google.com/store/apps/details?id=com.hbo.go&hl=en_US&referrer=utm_source%3Dgoogle%26utm...
Hi RodicaCristea,
HBO just launched its GO app for Android TV. It may not yet show up in the play store app from your TV. However, you should be able to install it from the Web page of the play store.
