Firmware updates
Witherwack
Firmware updates
Hi
I have a Sony Bravia KD-55S8505C and when i check for software updates it says i am up to date, and yet when browsing the web a new update is available
Firmware update to v5.457
How can i get this installed?
Regards
Ian
Tags (1)
1 ACCEPTED SOLUTION
Piscie
Hey @Witherwack, yup sometimes the TV isn't recognizing the latest software automatically, but you can update it manually using a PC connected to internet and USB stick.
Firstly download the software on your PC from here, then unzip the file and copy it to a blank USB stick, then plug it on your TV through any USB port. The update will start then
2 REPLIES 2
Piscie
Witherwack
Great advice, worked perfectly
 thank you
