Ethernet not connected
penfold72
Member
My TV, a KD 49XG8094, has recently started to say Ethernet not connected when I switch it on. It's directly connected to the router, via cat6 cable, and all other devices are fine. To regain s connection, I have to remove the cable from the router then put it back. This then works for a couple of days. I am wondering if it's not correctly asking for its DHCP lease to be renewed or something. Any ideas??
1 REPLY 1
penfold72
Member
Anyone any ideas. Did this again last night, and it completely refused to reconnect, even after a reboot of the TV.
Still the same this morning.... Tried setting a static IP, still nothing.
A router reboot cured it this time, but I am not sure its a router issue?
