Constant reboot needed
Techless
Nuevo miembro
Hi.
Our Bravia "freezes" and needs rebooting almost daily. Is this a common problem? It's also very slow accessing menus and has too many steps needed to get anywhere. Starting to wish we'd bought a TV for half the price!
Thanks for any tips.
3 RESPUESTAS 3
rooobb
And which Bravia are you talking about?
Techless
Nuevo miembro
Hi the TV is a Sony Bravia KD-49XG80xx
rooobb
@Techless it is not normal at all. be sure you have the latest firmware that you can check here https://www.sony.co.uk/electronics/support/lcd-tvs-android-xg80xx_x80xxg_xg81xx-series/kd-49xg8096/d... e, afterward, I'd suggest you to reset to factory the tv (you'll have to reconfigure it as you did when you bought it)
