Bravia. KD-43XD8088 Recording programs
stickerlee
Has anyone tried to  record a program say from the normal Ariel input and then switched over to another input say on HDMI. Will this disable/stop the recording. The reason I ask is I have a satellite box going in on my TV. Don't want to do anything untoward to my new TV
Thanks
2 ACCEPTED SOLUTIONS
you can record only from Aerial and SAT (one at time), not from HMDMI Input...
Manolo
stickerlee
Thanks for the input, fortunately I am able to do it the other way round, ie recording on my Sat Box built in HD and then switching to the Ariel input to now do a further recording if I so wish with the Bravia. Many thanks again always best to ask. Switching inputs does not effect the recording on my Sat Box as I'm switching the output connection not the input.
Stickerlee
2 REPLIES 2
Manolo
stickerlee
Stickerlee
