Bravia 8 stuttering since Firmware 114.602.030.1 update
baz8755
Member
I have been using my Bravia 8 65" for over a year on the same settings and it has been perfect. However a couple of weeks ago it updated to the firmware with the new EPG without channel logos.
Since then the image on quite often starts to stutter. This can be seen on OTA transmissions through the antenna and on inputs.
When using the antenna it will often begin to get jerky/stutter and I can change channel and change back again and it will be fine for a while but sometimes comes back again.
I have checked all my image settings and they have not changed.
It would appear this new version of firmware has broken things and many people on AVS forum, Reddit & Facebook are reporting similar issues.
Tags (2)
63 REPLIES 63
halloweenman
Same issue with latest firmware 114.602.080.1
LightFoot
Specialist
Hi @halloweenman   Have you added your voice to Sony Support.
fred1951
Member
Same for me. OTA channels stuttering and lip sync going way off. Changing channels does stop it for a short while but it comes back. Using the tv output from my Humax PVR to get a clean picture.  Come on sony payed good money for my Bravia 8 tv. This is near the top of the range, you must do better.
ashwasher
Member
Yes, we have had the same problem. TV okay when purchased and not okay once 114.602.080.1EUA firmware/software installed as recommended..
Seems to affect terrestial TV operation through the 'Live TV & Catchup' EPG.
Model Number K-55XR8M2.
I hope Sony will issue a remedy update soon.
ashwasher
Member
Maximus10001
Member
I wanted to add my experience in case it helps others with the same issue.
I have a 65-inch Sony BRAVIA 8 II (K-65XR8M2). The TV had been performing perfectly, but shortly after the most recent Sony software/firmware update I began noticing subtle but persistent motion judder/stuttering on live television.
My current Android TV build ends in 602080.
I have carried out quite a bit of troubleshooting:
● The problem occurs across multiple terrestrial channels.
● signil quality is 100/100 and signil strength is 90/100, so reception appears to be very good.
● I have tested different Motionflow and Film Mode settings.
● Turning Motionflow completely off changes the behaviour but does not make motion look completely right.
● Motionflow Custom with Camera Smoothness set to 1 improves the problem, but this feels like a workaround rather than a proper solution.
● Changing channel and then switching back has sometimes changed/improved the motion behaviour.
● Streaming content does not appear to exhibit the problem in the same way.
● Most importantly, I did not notice this behaviour before the recent firmware update.
I have raised this directly with Sony Support and my case reference is 29173275. Sony have so far said that the issue is not currently marked as a post-update problem, but they have asked me to carry out further diagnostics so the case can be escalated.
I’m posting here because I’d be very interested to know how many other BRAVIA 8 / BRAVIA 8 II owners are seeing the same thing following the recent update. If you are, it would be useful to share your model, firmware/build number and whether the problem began after the update.
Hopefully, if enough owners report the same behaviour, Sony can identify whether this is a firmware-related motion-processing issue and address it in an update.
baz8755
Member
Yep, I've pretty much followed similar steps and TBH Sony support have been pretty useless. Just blindly following a script with no proactive steps.
For many decades I have only ever bought Sony televisions (right back to the 80's Trinitrons) and would never consider another brand but this fiasco will certainly make me think twice before paying Sony tax on a future purchase.
Maximus10001
Member
New software update today installing it now
baz8755
Member
I installed it a couple of hours ago but too early to see if issue resolved.
I'm not overly optimistic as issues still reported on other platforms
doyled74
I must have had some update a few days ago as the problem seemed to have gone away.
Then I was watching TV last night and it was back again and with new behaviour 😒 where on a multi-cam TV show (Live at the Apollo) one front on view was very jerky but side camera/audience view not. Very weird.
I'll take a more detailed look later on and see if I can figure out how to get the version number.
How these software releases were ever, er, released is unbelievable. Is this Sony, Google, or both?
